Hi Hurst,
You could have a routine in the cleanup, which has the record switched off, which scans the ResultList for all the SIM results obtained within that sequencecall. I bit like the step I created to remove skipped steps
found here. You could maybe store your results in StationGlobals.
Could might use the SequenceFilePostStep Callback, this gets call after every step in the sequence file.
Or maybe the SequenceFilePostResultListEntry Callback.
There are a few possibilities
Regards
Ray Farmer
Regards
Ray Farmer
