I have tried to change the contents of my XML report generated in TS3.1 by changing the PropFlags_IncludeInReport. This works for some simple data types like numericteststep where I have removed the limits and step result from the report if the step pass. This is done from LV7.1 where I have created a reference to the step properties and then changed the flag with the GetFlag Property and SetFlag Property. I have posted a HTML (easier to open remote) example “MIGAExcludePassStepLimitsFromHTML.html” & a picture that shows the step structure “NumTestStepStructure.jpg”.
But it doesn’t work when my data type is getting more complicated. See CustomTestStepStructure.jpg. In this case it’s an array of containers (measurement - custom data type) that contains some containers (limits and channel – custom data type). I have removed the PropFlags_IncludeInReport on all the custom data types (in the top of the tree) except on some of the items in the last type in the tree (Status, Read.Voltage_V, Limits.Voltage_High_V, Limits.Voltage_Low_V…).
The XML style sheets doesn’t show my data when I remove the PropFlags_IncludeInReport of the Measurement Array (if it’s on all the sub-properties are shown. Not wanted because off the size). I assume it’s a bug (shows data in HTML) if some data in the structure has this flag enabled?
I can see in the source of the XML report that the flags are added to each property. These flags have the correct value from the custom data type, but the style sheets can’t show them correctly. It’s possible that NI will make a fix to this problem?
I have also tried to change the PropFlags_IncludeInReport on my custom step properties from LV7.1 like above. But my changes of the flags dynamically aren’t included in my XML report (new flags aren’t added to each property). Why? Is it because of the data type? Is it because I do it in a Post Step? Is there a solution?
I am looking forward to hear from you,
Best Regards,
Morten Pedersen
CIM Industrial Systems A/S
