Reply
Dumping Variables to Text File, separate from TS Report
Go to Solution
Highlighted
Hi All,
I know I can probably do this in TestStand using LabView, however, that is not a luxury I have.
What I am trying to do is, when a failure occurs, dump a specific set of information into a separate (most likely text file) log file apart from the standard test stand report.  For example, I might be keeping track of some buffer or test equipment status in stationglobals, when a test fails, I want to dump part of the station global into a different log, again, apart from the test stand report, is this possible?
Seems like the closest thing I found looking through TS and the support forums is to use ActiveX calls to maybe MS Word or Excel and generate something from there?  I was hoping for something a bit more simple?
Mike
Message 1 of 3 (910 Views)
Reply
Accepted by topic author mwcmwc
‎08-27-2015 06:09 PM
Re: Dumping Variables to Text File, separate from TS Report
Hi Mike,
Try This:
Write Method
Syntax
PropertyObject.Write ( pathString, objectName, RWoptions)
Purpose
Writes the contents of an object to the file specified by pathString and associates the name specified by objectName with the object in the file.
Remarks
If you call this method on an alias object, TestStand generates the stream using the object to which the alias refers. This method does not include alias subproperty objects in the stream. Refer to IsAliasObject for more information about alias objects.
Parameters
pathString As String
[In] Pass the pathname of the file to which to write the object data.
objectName As String
[In] Pass the name to associate with the object.
RWoptions As Long
[In] Pass 0 to specify the default behavior, or pass one or more ReadWriteOptions constants. Use the bitwise-OR operator to specify multiple read/write options.
For example, make a statement step in a sequence with local variables and run it:
Locals.Write ("C:\\temp\\Locals.txt","Locals",0)
This will generate a text file with the values of the local variables. You can use this on any object, but you'll probably need to lay with the options to get what you want.
Hope this helps.
-Jack
Message 2 of 3 (905 Views)
Awesome, totally didn't see that, and I can use read to get the variable back.  Thanks!!!
Message 3 of 3 (897 Views)
Reply
