03-23-2017 11:14 PM
Hi
At the moment in TestStand 2016f1, when a test fails (Sequential Model - Test UUTs) , I have to stop the execution to view the test report to see what failed. For debugging a sequence this is getting quite annoying.
What I would like to do is in Post UUT callback, (ie. after fail banner is displayed) is call a Display Report VI to display the test report (which I can do conditionally if pre-expression is Parameters.Result.Status != "Passed" in Post UUT callback).
VI would contain TestStand UI ReportView Control.
Having put a break point at the end of Post UUT, I can see the report is generated as I can view it.
So I feel what I want to do should be possible.
I am just struggling to join the dots to get something working...
I thought I might need a Execution view manager for this VI.
From Docs:
An application must have one ExecutionView Manager control for each location, such as a window, form, or panel, in which you display an execution or let the user select a current execution.
I then need to find a way to hook it into the sequence that is running.
I can launch the external viewer - but IE is a bit of a pain with its enable scripts and allow blocked content warnings to dismiss...
Then tried to display a temporary report which doesn't work either... example is attached.
I have tried quite a few things with no luck, I would really appreciate it if someone if a bit more knowledge of the TestStand API could give me some pointers.
Cheers
Nick
Solved! Go to Solution.
03-24-2017 02:53 AM
@NickNZ wrote:
[...] For debugging a sequence this is getting quite annoying.[...]
You are aware of break points?
You know that you can configure break points to be conditional (e.g. break only when sequence fails)?
The report is not a tool for debugging in the first place....
03-24-2017 03:24 AM
Hi Norbert
thanks for your reply.
yes used break points in TS. Not conditional ones though (except in LabVIEW). In this case half the tests are calling a DLL that the software guys wrote to interface with the UUT. Its the same interface they use for their unit testing, however I have discovered that a unit testing pass does not imply a functional testing pass...
My test sequence basically works now - its the fine tuning and getting reliability up. Optimising the areas that need it. Hence when the sequence fails I want to jump to the report to see what failed and the values... don't really want to scatter conditional breakpoints all though the sequences. I have broken my main sequence up into suites of sub-sequences, which if one fails, the following ones are skipped, but knowing something in suite 1 failed isn't helping.
Also the sequence is not quite at a point where I could implement auto retest and just let it run, dumping the results to a database. I also had a oversight and left out specifying a software reset, (doh - and can't get resource now to fix!) so if some failures happen I can't recover and need to manually reset. I would also have to skip some of the tests that require operator interaction.
I also think it would be useful for our production techs to be able to easy access a report when a unit fails, rather than retesting not knowing the issue, or waiting until all units have been processed. We don't do high volume manufacturing, and they are a couple of levels above an operator in resolving issues.
Having said that you have got me thinking that a condensed report of just the failures at that point would be even more useful (for me). That's probably a harder problem for another day. Just getting the report efficiently would keep me happy in at the moment.
Nick
03-24-2017 04:45 AM
Then you should create two reports. One "normal" and one "failure". The failure is configured to not list Passed/Done/Skipped steps.
Then you can display the failure report in the report view as usual and the operater can review the report.
03-26-2017 03:10 PM
Two reports is a good idea. But doesn't solve my issue of displaying a report in post UUT, so the sequence does not have to be exited.
03-27-2017 04:18 PM
Hi NickTrim,
I agree with Norbert that creating two reports would be a good idea. My thoughts are that you could then set up a post UUT step to determine whether the UUT status is Passed/Failed. If the status is Failed you could write an expression to call a VI that opens the Failed report. This way you would only be opening the report if the UUT failed and doing nothing if it passed. Hopefully this helps!
03-27-2017 04:50 PM
Hi
"call a VI that opens the Failed report" - this is where I got stuck for the initial post. Please see my attached VI example to initial post. I was trying to open the report into a Teststand report view control. Tried heaps of ideas but couldn't quite get it to work.
Yesterday I just disabled trying to open the report in the report viewer, and just left it to open in default viewer.
I then figured out what security setting to disable in IE so I didn't get the two warning message prompts.
This worked OK and I am happy enough now.
Regards
Nick
