11-30-2005 12:27 PM
11-30-2005 03:42 PM
12-01-2005 08:53 AM
True. However, that is not what I'm asking. I want to disable the screen updating. Is this possible?
Tony
12-01-2005 11:34 AM - edited 12-01-2005 11:34 AM
Hey Tony,
There is an option to hide the execution windows as well. It is located under Configure>>Model Options. If this still isn't what you are looking for, could you give us a little more specific information as to what you want to disable?
Message Edited by Patrick P. on 12-01-2005 11:35 AM
12-01-2005 11:36 AM
Some of the ways you can hide the test socket windows are:
a) Add a ModelOptions callback to your sequence file. In the callback, set Parameters.ModelOptions.HideExecutions to true.
b) Modify the process model. For the batch model, remove the precondition on the Hide Executions? step in the Initialize TestSocket sequence.
c) Open and close Configure>>Model Options... to ensure there is a <TestStand>\Cfg\TestStandModelModelOptions.ini file. Edit the file in notepad. In the same section that has:
NumTestSockets = <4 or some other number>
Add on a new line:
HideExecutions = true
Don't change the section that has:
NumTestSockets = Num
12-01-2005 11:38 AM
