Sorry, Pressed enter to quickly....
So heres he question...
MainSequence in "Sequence_1a.Seq" runs the step "SequenceCall", which calls a sequence called "DoSomething" in "SequenceFile_2a.Seq". Nice and easy so far....
Now, the "DoSomething" Sequence needs to call a sequence which is in "Sequence1_1a.Seq"......But, the sequence file name, can't be hard coded because the there are multiple versions of the file "Sequence_1a.Seq" (eg. "Sequence_1b.Seq").
So how can "Sequence_2a.Seq" determine the file name of the sequence that called it?
Now I know one solution is to pass a parameter into "Sequence_2a.Seq" with the relevent info in it(Possibly the best way). But the files have already been written and it would be a long task to change everything to include parameters and the handling for it.
Is there a way using the API to determine the sequence filename of the caller to the "DoSomething" Sequence...?
Any help would be appriciated...
