NI TestStand
Detaching DLL file
Hi All,
I'm new to TestStand and I was experimenting with making calls to a C/C++ DLL using an action.   I designed a simple DLL in Labwindows/CVI and call one of the functions in TestStand using my action.  Calling the functions works fine, but my problem is that once I call this DLL from a TestStand sequence, even after I stop the sequence TestStand does not let go of the DLL.  I have to close the sequence if I wish to rebuild/delete the file.  Is there a way that I can explicitly tell TestStand to relase the .DLL file once the sequence has completed?
Using:
TestStand 3.1.0
WindowsXP
(2,729 Views)
Select File->Unload All Modules
You can also change the unload option under the Run Options for your step.
Ryan K.
(2,726 Views)
Awesome, thanks ryan that's exactly what I was looking for.
(2,722 Views)
