Hi All,
I'm new to TestStand and I was experimenting with making calls to a C/C++ DLL using an action. I designed a simple DLL in Labwindows/CVI and call one of the functions in TestStand using my action. Calling the functions works fine, but my problem is that once I call this DLL from a TestStand sequence, even after I stop the sequence TestStand does not let go of the DLL. I have to close the sequence if I wish to rebuild/delete the file. Is there a way that I can explicitly tell TestStand to relase the .DLL file once the sequence has completed?
Using:
TestStand 3.1.0
WindowsXP
