02-03-2014 06:47 AM
Thanks for the info Norbert. I am still in the learning phase and appreciate people taking the time to help out. The point of the my last post was to show an easy way to create the bug that I found, in case NI wants to fix it. 🙂
05-04-2015 11:17 AM
I found the same issue when try to deply an application in TS2013 32bit.
If the Hw configuration file is initially inserted (filepath) and selected the deployment utility doesn't ask for all the installer sources and the Build process terminates creating the image but aborting, without explanation, the installer.
I try to check the various log file and I found only these information inside the "TSDU Installer Build Log.txt":
Merging Table: _Validation
o Merging row: Binary
o Merging row: Component
o Merging row: CustomAction
>> Error: Failed to merge Row: CustomAction into Table: _Validation
... (at the end of log file)
Done loading manifests. Skipped (0) + Loaded (845) = Total (845)
[PRODLIST_LOAD END] Thu Apr 30 17:19:00 2015
Initializing MetaAutoPlay instance
Creating Autoplay thread...
Sending message to begin AutoPlay supression!
After removing the check on Hw config file the deploy utility asks for some other installer files/packages and the the build sucesfuly generates the installer (even after rechecking the hw config file).
I think this is a bug of Deployment utility.
Anybody can confirm this?
Sincerely
05-05-2015 11:46 AM
The deployment utility has drastically changed since this thread was created.
This issue might have been fixed in TestStand 2014
If anyone gets a chance to test this is TS 2014 and is seeing the same issue, please post here.
10-25-2017 12:43 PM
I am seeing this error in TestStand 2014 SP1.
The Build log says "Finished Deployment Build" then "Aborted"
Logfile includes "Error: Failed to merge Row: CustomAction into Table: _Validation"
Also at top of log file: NIMdf.dll [MODULE NOT FOUND]
I get this outcome when trying to Install TestStand Runtime. If I don't check Install TestStand Runtime it builds fine....
10-26-2017 03:26 PM
@dkleffner,
Since this thread has been dormant for some time, it might be best to make a new thread in order to get some fresh eyes on this issue!
