Is it in a search path for your VI's, same location as the exe or LLB?
I am assuming you are using an ActiveX Labview server on your target machine or are using the OI as the server, so it probably wants to be in that directory.
Or you can specify in the ini file of the ActiveX Labview server under the section [
the key would be viSearchPath, eg
[TestStandLVRTS]
viSearchPath="c:\My Application\*"
I would have thought the two versions of DAQ are probably compatible.
Ray Farmer
Ray Farmer
