03-28-2013 11:37 AM
I've built a DLL using labwindows that calls a subsidiary static library. I've added a step in Test Stand that calls this DLL. On my development station all is good. The subsidiary library is called. But, on a deployed station I keep getting a "Cannot load DLL".
According to the reference manual, I can preload the subsidiary librarys by using the CVI adapter. I get the same error on my deployed station...
Solved! Go to Solution.
03-29-2013 05:54 AM
You get an error "Could not load a DLL" when one of the dependencies is missing.
Please check it this way :
Download free dependency walker --- http://www.dependencywalker.com/
Select the DLL ( deployed machine).
It will show which dependency component is missing in the deployed machine.
For CVI..
Since you are using a static libarary - did you include it in the build when you build the project?
It should be embed within your DLL. ( using add files to DLL option in the CVI target settings).
Hope this helps.
03-29-2013 10:35 AM
I tried the dependency walker. A very nice tool.
After running dependency walker on my DLL, it threw an error that I was missing a DLL. Turns out I had configured the target settings on one my static libraries as a DLL rather than a static library. Changed the settings and rebuilt it.
Once I get access to that deployed bench again I'll check it out, but I'm pretty sure this fixed the issue.
Thanks for the information...
03-29-2013 02:11 PM
Still get the same error.
I've added the static libraries in the target settings of the CVI project, including adding the libraries in the Test Stand adapter.
03-29-2013 02:21 PM
After posting my last message, I realized my problem.
I recently upgraded Labwindows to 2012, but my deployed station only has the 2010 rte. so, I rebuilt using version 2010 and all is good now...
Thanks for the help and sorry for the confusion.....
