02-14-2010 11:16 PM
02-15-2010 08:09 AM
02-16-2010 10:45 PM
Thanks Vidula,
The link gave me some additional information about the Report Generation in the Test Stand. But my task is to customize the Report generated by the Test Stand, they already have three type of Style sheets to do that, but I have to entirely change the apperance of the Table according to the specification. I found a way by editing the Style sheet to get the desired appearance. Since I am new to the scripts language used to create the shyte sheet, am looking for an alternate and easy way to do that, any idea???
AshwiN
01-28-2013 03:22 AM
Hi Ashwin,
I think I have your same problem. I saw that every customization, e.g. that one explaind in some manuals or getting started, are basically based on customization of report
generation by using teststand menu.
Did you find a solution to our problem?
Thanks.
02-12-2013 08:41 AM
I have for test made a copy of one existing stylesheet
i know xslt and i think the main place to edit and customize for you both is the part starting from
<xsl:template match="/">
I saw that, there are some comments from NI.
It could help if you would use Notepad++ with the xslt/xml plug in or altova XML Spy.
