NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
pvki
Accepted Solution
Custom user interface for parallel execution?
my question is about customized user interfaces for executions with the parallel model. At my current project, we use the parallel model with 4 test sockets and at the user interface we must have 2 string indicators for its execution, one that displays messages to the user and one that has the function of a streaming indicator that displays information throughout the test, showing also the time instances. So, in total 8 indicators that display in parallel information about the 4 independent executions. Till now, I managed to create the UI only for sequential mode, using 2 simple string indicators and sending messages from the TestStand to the strings through UI Messages. My problem is that I don't know how to implement this functionality for more test sockets.
Attached you can find images from the front panel and the blog diagram of the GUI as it looks now.
I am very new at TestStand (I know it only for the last month), so I expect that my question and the case description are not so clear, so please let me know if sth is poorly explained.
I would be grateful for any help.
Active Participant
dug9000
Re: Custom user interface for parallel execution?
Basically, whenever you get a UI message related to an execution (e.g. UIMsg_StartExecution, UIMsg_Trace, etc.) you need to determine which testsocket the UIMessage applies to and then update the corresponding UI controls. One way to get the testsocket is as follows:
testsocketindex = uimsg.Thread.GetSequenceContext(0, frameId_Notused).AsPropertyObject().GetValNumber("RunState.TestSockets.MyIndex", 0)
Also, once you know where a particular execution goes, you can associate that execution's Id (i.e. Execution.Id property) with the control and just look at the execution Id instead.
Hope this helps,
-Doug
Knight of NI
Dennis_Knutson
If you know C at all, it is simple to make the modification to the existing user interface. All the code is there. It would require you to also have a copy of LabWindows/CVI.
Member
pvki
Thank you very much!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
