i created an OPUI in Visula Studio 2012 C# which references from TestStand 2013 this:
NationalInstruments.TestStand.Interop.API
NationalInstruments.TestStand.Interop.UI
NationalInstruments.TestStand.Interop.UI.AxControls
NationalInstruments.TestStand.Interop.UI.Sopport
Everything is running fine under Windows 10 64bit.
Now i have the problem that my OPUI is not running with TestStand 2014 (64bit).
Do i simply have to replace the four references and recompile and everything is good?
The TestStand-process is starting (becaue i see the 7 days-evaluation window) but after i start the testplan i get:
Default Critical: 0 : System.Runtime.InteropServices.COMException (0xFFFFBC6B): Index out of range.
bei NationalInstruments.TestStand.Interop.UI.ISequenceFileViewMgr.GetCommand(CommandKinds cmdKind, Int32 Index)
bei NationalInstruments.TestStand.Interop.UI.Ax.AxSequenceFileViewMgr.GetCommand(CommandKinds cmdKind, Int32 index)
Is there any other way so that i can use any TestStand-version or do i always have to recompile?
