Hi Bruno,
I am going to assume you are familiar with labwindows/CVI and its the TestStand you are new too.
I would start by reading through the TestStand Manuals in particular relating to using CVI with TestStand.
There are also quite a few example that come with TestStand as well as ones on the NI website NI Developer Zone.
I believe they are some tutorials you can work through as part of the TestStand documentation.
If you are not familiar with Labwindows/CVI, then the same applies. The CVI package comes with examples and there are one relating to DLL's.
You might even consider doing the NI basic courses for CVI or TestStand or both.
Hope this may point you in the right direction to getting started.
Ray Farmer
Ray Farmer
