10-26-2015 10:26 AM
Environments: Test Stand 4.2.1, Labwindows/CVI 2009
Menu: Configure ->Adapters->Labwindows/CVI
Issue: When I change the execution from "In-Process" to "External Instance" and then try to step into the CVI debug build , I get the following error:
No .pdb file is built when I invoked the Build-Create Debuggable Dynamic Link Library from LabWindows command.
Debugging when the adapter is set to "In Process" works fine.
10-27-2015 06:26 PM
Did you get a chance to look over this Knoledgebase article? It talks about a step by step way to debug a CVo application from Testand. If you follow this, do you still get an error?
Here is the link:
http://digital.ni.com/public.nsf/allkb/0C0EBF781B7702E886257620005368B5?OpenDocument
Please let me know if it helps.
