I have an error occur when I try to specify the module on a step using the.NET module adaptor.
The actual error is included as a jpg attached to this message, but roughly includes . . .
"Error while accessing the .NET assembly.
Could not load file or assembly 'mscorcfg, Version=2.0.0.0 ........ The system cannot find the file specified."
The following link was a message by Jason Davis on the same problem and it was suggested that the mscorcfg assembly was either missing or not loaded into my Global Assembly Cache (GAC).
It appears I do have this file but on viewing its properties it appears to be version 1.0.5000.0 dated 20th May 05. Do I need to get hold of version 2.0.0.0 and how do I check it is loaded into the GAC (and how do I load it if indeed it isnt loaded)?
I have Microsoft Development Environment 2003 (Ver 7.1.3088) and Microsoft .NET Framework 1.1 (Ver 1.1.4322 SP1) Installed and am using Teststand 3.5
Any help would be greatly appreciated.
Cheers, Barry
