09-24-2015 04:35 PM
I am having an issue with a corrupted header when my test errors out or fails the first time the file is created.
What I can see is when the sequence context fails, or errors out, the csv file header will stop at that step.
Looking into the subVI, there is a For Loop that creates the header of the file. NumberOfSteps in the test stand sequence are counted and are entered into the number of iterations for the For loop to create the header.
This vi runs of off LabVIEW 2013.
Any help would be appreciated.
I have attached the vi in question.
AlphaDg
09-28-2015 03:36 PM
Hi Alpha Dog,
Unfortunately I was unable to replicate your issue because the file you provided was missing some dependecies. Could you try to build a small program that narrows down and illustrates the issue your are having?
