05-26-2005 12:42 PM
06-02-2005 07:29 AM
06-02-2005 09:44 AM
07-11-2005 02:34 AM
Hello!
When programming with the ActiveX API in TestStand you can get object references to the sequence file, sequence, steps, execution and so on that is executing at the moment. By using these references you can close the open sequence file and the re-load them the ordinary way.
One of the methods you can use is: SequenceFile.UnloadModules
Jimmie A.
Applications Engineer, National Instruments
07-19-2005 04:19 PM
Note: To reload a process model or a client sequence file, the additional requirement is you must close any execution that is using or previously used them.
