By this link you can check the discussion similar to your question. The point is that you can use some free pdf printer, and afterwords programatically convert to pdf-file.
But, unfortunatelly, there is no such built-in functionallity.
Finally, you can create your own report processor, which will create directly test reports in pdf format. Could be quite usefull, by the way...
Sincerely, kosist90
