Continue execution, with options
I need to create on application were if a step is fail must to running a windows error box, from where the user has the possibility to continue execution, with next options :
1. Next Step (the step witch will running will by the next step from current sequences, or with next sequences if the current step is the last step )
2. Same Step (rerunning current step )
3. Next Sequences (the next execution will by the next sequences)
4. Same Sequences (rerunning current sequences )
5 Halt (stop execution)
For implemented this I use the callback SequencesFilePostStepFailure were I put the my error box with the facility presented upstairs.
My questions is witch is the modality to implemented this, to execute the facility
Thank you,
Best regards
