09-21-2015 04:17 PM
I have an FPGA that is doing a loop test. The FPGA will TX an array and will store the RX array to a variable. I'd like to use TestStand to comare the TX array with the RX array.
I know I can step through the elements of an array to compare each element with a Numeric Limit Test and I know I can do it with a multiple numeric limit test but with that I have to manually put in every index and the Array will not always be the same size.
Is there a way in TestStand to say does Array = Array and then print the elements without doing the loop?
09-22-2015 06:07 AM
I tried Locals.y==Locals.x for the if condition where both x and y are numeric arrays.
It worked fine when all the elements were matching and array size was same.
To print any variable use additional result (check help).
Hope this helps.
Ravi
