01-17-2006 09:26 AM
01-17-2006 10:10 AM
01-17-2006 12:46 PM
Good idea, but I want to be able to switch sequence files without closing the LabVIEW Application.
That's why I was looking for a callback linking to the Station shutdown instead of the SeqFile Close.
01-17-2006 01:42 PM
Are you switch process models or just sequence files. If you leave Station Options>>Model>>Station Model set to the process model with the unload callback, it should work fine.
Also, it will not be a problem if you then load sequence files that explicitly require different models because the engine will keep the station model loaded.
01-17-2006 01:53 PM - edited 01-17-2006 01:53 PM
Cool Idea, thanks for the tip. I won't be changing Process Models.
So the idea is that when the application is closed, the ProcessModel Sequence File will be closed first, which will involve running the SequenceFileUpnload callback?
Makes sense - I'll try it.
SWEET. It worked, thanks.
Message Edited by 10Things on 01-17-2006 01:57 PM
