02-26-2013 07:20 AM
Hi !
Is it possible to clone variables ?
I found the way to use the clone method with steps, but I can't find the way to do it with variables.
What I did is get the reference onto the 'Locals' in sequence (the reference is a PropertyObject). Then cloned this PO using the Clone method, which returns a reference on the cloned Object.
I have the reference of a sequence in another sequence file, in which I want to copy my variable. But I can't find any method from the Sequence class which would allow to add the cloned variables using the clone refrence.
Any idea ?
02-26-2013 09:11 AM
I found a solution using the cast AsPropertyObject and inserting SubProperties with the correct lookup strings !
02-26-2013 02:54 PM - edited 02-26-2013 02:55 PM
Clone is possible,
Just see these threads, there were some examples
Juergen
