05-28-2014 05:41 PM
Hi Aaron,
I'm trying to follow what your doing but do not have RunState.Caller.Locals.ReportPath in GetReportFilePath at run time. Would you mind posting an example sequence file? I can't tell if my report options are set different or what I am missing
My end goal is to get the report name then copy it to a different location using the Call Executable step, but I am stuck at getting the report name.
Pat
05-30-2014 08:39 AM - edited 05-30-2014 08:41 AM
Pat,
Here you go. I really think the only thing you need is the GetReportFilePath Callback. I have the ReportOptions callback in here just to enable a report for every UUT.
p.s. You might get a type conflict when loading the sequence, I have some customizations made to the standard types, just use the default Types.
06-05-2014 08:27 AM
Hi Aaron,
unfortunately your example has to be opened in TS2013. Is there a chance to get a TS2012 version? Or a textual explanation?
Thanks in advance,
Klaus
06-05-2014 09:57 AM
Klaus,
Saved for TS2012. Hope this helps.
