01-23-2007 11:46 AM
01-24-2007 08:46 AM
Hey Troy12,
Yes, there does appear to be a way to set these programatically - you can do it using Active-X steps. You'll need to get a reference to the Station Options in the TestStand API 3.5, then as an action, Set Property, and then select Debug Options. From there you can set the input value to 0 to disable all debug options. The TestStand help file has more details if you search on "DebugOptions Constants".
Also, you can disable Report generatation using the Report Options Callback and setting the "Parameters.ReportOptions.DisableReportGeneration" to True.
Hope this helps.
-Jack
01-24-2007 08:54 AM
