NI TestStand
Change path to user file and station globals
Hi All.
I have lot of TS programs that shares the same station globals and user file.
But how do I change the path to these files, If I go to view->path and then check these 2 files and press ok, then the next window is empty.. I want to change the path so I can have the files on a network share.
Anyone have any ideas ???
Kind regards Bojer
(2,977 Views)
Found how to change users file... had not seen the option in station options.
So now I only need to find out how to move the path to station globals.
Kind regards Thomas
(2,976 Views)
Thomas -
The TestStand Station Globals file is stored in the \Cfg directory. Prior to TestStand 3.1, the config directory was fixed. In TestStand 3.1, we allow you to define where the config directory should go. All files are stored in this new directory, not just the Station Globals. If you are using TestStand 3.0 or earlier, there is no way to share the files under the config directory.
Scott Richardson
(2,968 Views)
