I am currently trying to deploy quite a simple sequence but am suffering some diffculty with deployment Vis themselves.
Using the "Deploy Teststand System" dialog. I am trying to deply from a workspace file containing all the relevant files. The files, as displayed in the 'distributed files' tab, are as expected, and the installer options are set as required. However, on building the package the following error is returned (I include the entire log since it is not all that big).
"Starting Log.
Processing Workspace...
Done processing workspace file
Beginning build process, please wait.
1:29 PM
An installer was not created due to an error
The build is finished
1:29 PM
Error Code:7
Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW error:
Invoke Node in TestStand - Dist Cmp Settings to Disk Hier.vi->TestStand - Build VI Distribution.vi->TestStand - Build VI Distribution AX Wrapper.vi->TestStand - Build VI Distribution AX Wrapper.vi.ProxyCaller
When I open the responsible VI it has no broken arrow, so I can only assume it is a runtime error of some description. Also the diagram is passworded, so I cant take a look around the code.
If anyone has any ideas I would be very grateful.
Cheers,
Barry
P.S. I have LabVIEW 7.1.1 installed with Teststand 3.1
