I have several .BMP files that I want to deploy with a TestStand project. The files are in the workspace, and I specified a destination directory as "Personal", in C:\Bitmaps. When the deployment completes, I get an error that states "Error: the following file(s) could not be copied:", followed by a list of the bitmap file names. the source directory is not the same as the destination directory.
I tested out including a image file in a TestStand workspace and had no difficulties deploying this image. What version of TestStand are you using? What happens if you create a basic workspace with just the image? Can you deploy fine from that?
Jonathan, Thanks for the reply. I found the problem. When I specified the "Personal" folder to install the files, I used "C:\Bitmaps", but when I removed the colon, and entered "C\Bitmaps", it worked. I am using TestStand 3.5.
