Hi Brian
Parameters are one way you can pass data from a calling sequence to a subsequence. From the main sequence, right-click on your subsequence and select "Specify Module...". In the "Parameters" section of the dialog box, you should see any parameters that you have for your subsequence. You can then assign these subsequence parameters to have the same value as a parameter from the calling sequence, a local variable from the calling sequence, a constant, etc. In regards to your question about naming parameters, you do not need to have parameters of the same name in both the calling sequence and the subsequence, although you could have them be the same name.
Russell G.
NI Applications Engineering
