09-26-2005 12:29 PM
09-26-2005 04:36 PM
In your process model, there is a ReportOptions Callback that you can override all of the values that are saved in the Configuration Entry Point. You can override this callback in your sequence file, or modify the process model.
Allen P.
NI
09-27-2005 10:13 AM
The ReportOptions callback is working nicely. Thanks for taking the time to reply with the soln!
Pete
11-08-2005 12:47 PM
KnowledgeBase 2V39NFO6: Logging Different Sequence Files Data to Different Databases
Gives Specific information on how to do the for Databases
Question: Can anyone give the same kind of specific infomation to change the Directory, where TESTSTAND Test Reports are sent after a Sequence Executes using Callbacks.
I followed >>>
and it works well. I have 9 different models of UUT using different TESTSTANDSequences that need a Separate Database and Test Report Directories. The call back to the Database works.
Need the call back for the Test Reports
Thank you
11-09-2005 08:07 AM
11-09-2005 10:53 AM
