08-05-2014 01:47 PM
Hi everyone,
Is there a way to resize the Message Popup box (found in the Insertion Palette)?
Thanks so much!
08-06-2014 07:00 AM
The dialog box resizes automatically depending on the content.
You can also enable the user to resize the dialog to his own needs in the Layout tab.
Norbert
08-06-2014 08:41 AM
Thanks Norbert. One more question I have for you:
What if the Message Popup box is too small and you want it to be bigger for operator's to see it better? Is there a way to do this so that the user does not have to change the size all the time?
Thanks so much!
08-06-2014 09:33 AM
Hm, you could enter "empty" text or insert an image of the desired size.
The last option would be to create a custom popup dialog yourself (e.g. by using C# or LabVIEW) and use that instead of Message Popup.
Norbert
