The XML style sheet should not be embedded into the report file. Since XML would represent raw data, you would not include information on how to interpret it. However, there is a way for you to easily reference your style sheet, even when it is on another computer.
1) Go to Configure >> Report Options in TestStand, and change the style sheet file to your style sheet.
2) Uncheck the "Store Absolute File Path" box.
3) Make sure the style sheet is in the same folder as your report.
You can view this on any computer, and now a relative path is now being used to reference the file.
Allen P.
NI
