06-18-2012 11:10 AM
I just started a new internship and for this job I need to incorporate TestStand and Windows Forms in Visual Studios to accomplish certain goals.
One thing I need to be able to do is write certain test variables to the reporting functionality in TestStand. I have a subsequence in a step that allows me to edit using a windows form and that form takes a SequenceContext so that I can use that in the C# code. I am able to access the properties and methods of the Step property of my SequenceContext object, however if I tried to access anything else like .Report, I get a null error or "Object not set to a reference" error.
Like I said I am quite new to this program so I'm sure that more information is likely needed and I will specify whatever else will help solve the problem.
06-18-2012 12:50 PM
06-19-2012 07:26 AM
This unfortunately is not helpful. I have seen this and looked through it but here's the main issue. if this is the code:
Form1(SequenceContext seqCon){
this.seqCon = seqCon;
seqCon.Step
seqCon.Report
In the above code, seqCon.step is fine and I can access all of it's properties but seqCon.Report is null and crashes the program
06-19-2012 09:37 AM
By default, the report is not generated until the end of the sequence and only if you are running using a process model.
-Doug
