02-01-2016 02:41 AM
Hi,all!
I'm a new hand to TestStand, so I have several problems.
I generated a numeric array in LabView, and display it dynamically in graph. When I want to use TestStand to generate the report, can I access the array directly? If not, how to do it? My ultimate purpose is display the array as graph in the report.
Thanks a lot for your help.
Solved! Go to Solution.
02-01-2016 08:16 AM
You have several options here. Pass the array back to TestStand and log it as an additional result. Or you can just put an image of the LabVIEW control in the report.
Option 1: https://decibel.ni.com/content/docs/DOC-38945
If using Option 1 it is important to understand this: http://digital.ni.com/public.nsf/allkb/7AE2EB304D4F9D4F86256B8100795B83
Option 2: http://www.ni.com/example/30736/en/
It also depends on which version of TestStand you are using as well as which type of report you want to generate.
02-01-2016 08:18 PM
Thank you.
I saw a .dll file in the example provided by NI. Is the file the must to the access process from TS to LV?
02-02-2016 08:04 AM
No the .dll is not necessary. You should be able to pass data from LV to TS through the connector pane.
02-02-2016 07:30 PM
Thank you very much!
