NI TestStand
Can Test Stand Additional Results display a hex String?
I have a VI called by Test Stand where four fields (which are Hex display in Labview)
and I would like to display these as the hex numbers that they are in my report as additional
results but becasue they are not ASCII they look like garbage.
Do I need to change my VI to display these as an ASCII string in my VI or is there a way
to display these in the additional results in Test Stand just as they appear in the Labview VI?
(3,772 Views)
Hello robojeff!
I pulled up the "Using LabVIEW with TestStand" User's Manual and Section 4 talks about using LabVIEW Data Types with TestStand.  On page 4-4 under teh section "Calling VIs with String Parameters" in the User Manual talks about what happens to hexadecimal values.  This should answer your question!
Casey L.
(3,752 Views)
http://forums.ni.com/t5/NI-TestStand/How-to-convert-a-string-to-hex-in-TestStand/td-p/2944788
Kristen M
Automated Test Product Marketing Engineer
(3,743 Views)
