Can I rename my Mainsequence within a sequence file to another name, and then create a new Mainsequence?
The reason I ask is because I had a sequence file where my Mainsequence contained all of my steps. I then needed to have the ability to call one of two subsequences based on a button selection. So I renamed my Mainsequence to Sequence1, added a Sequence2, and created a new Mainsequence that simply called Sequence1 or Sequence2. That part worked OK, and I was successfully able to call either of those sequences. After I did that however, my test results would no longer be written to my report. A report was generated but only contained the header info and the 'End of Report'. All the properties for writing reslults to the report were set properly at the step, sequence, and station level.
Was this problem caused by renaminig my Mainsequence or is something else going wrong?
