09-29-2006 05:03 PM
10-02-2006 01:05 PM - edited 10-02-2006 01:05 PM
TestStand does not call Custom substeps. You use the TestStand API to invoke a Custom substep from a code module or an operator interface.
My suggestion would be to place the “configure” step in the Setup group of the subsequence simply because this is the purpose for which the Setup group was designed.Have a great day,
Ecleamus Ricks, Jr.Message Edited by Ecleamus R on 10-02-2006 01:05 PM
10-03-2006 12:48 PM
10-04-2006 06:57 PM
Sounds like an interesting test application
I need to know more about your application because a more elegant
solution may not be worth the effort. I’m curious, what will this custom substep
actually do? Will it be the same configuration VI regardless of the sequence
that is being called? If so, a callback wouldn’t be a bad idea.
