NI TestStand
Calling DLL with local arrays as arguments
Is it ok call a dll and pass local array as an argument assuming that the function declaration matches TestStand's definition?
Inside my dll do I access them as Integers or Doubles?
CT
(3,544 Views)
Yes, TestStand supports passing arrays directly into C functions. You need to make sure the prototype you specify in TestStand exactly matches your C prototype. If you specify that the array is an array of 32-bit integers on the TestStand side, then that is what you should access on the C function's side. In your screen shot, you show two array parameters, one is an array of doubles and one is an array of 32-bit integers. Whatever you specify it as on the TestStand side is what you should expect to get on the C function side. TestStand will do the conversion of the numbers for you.
-Doug
(3,523 Views)
Thanks Doug.
This is what I was expecting.
CT
(3,520 Views)
