07-29-2013 09:49 AM
is there a way to create a callback-sequence that automatically executes when i press the terminate-button to stop the sequence?
In this sequence i want to turn off the instruments.
Thanks for help
Solved! Go to Solution.
07-29-2013 09:54 AM
As "Terminate" still executes all steps of the Cleanup step groups (up until the process model), you should place the uninitialization of instruments into that step group.
The reason is that you don't bind that security feature to a specific GUI. The security feature will also work in the NI TestStand Sequence Editor or any other GUI you are using to run your sequence(s).
Norbert
07-29-2013 10:03 AM - edited 07-29-2013 10:07 AM
I tried this but it is not working.
I put a Popup in Cleanup. But when i press "terminate" / "terminate all" then cleanup is not executing.
Whats wrong here?
Edit: Its working...
Thx
