NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
jojp
Accepted Solution
Call Executable: RunAs
Using Win7 I´m sometimes force to run good old applications as Administrator. How can I do this with TestStands Call Executable step?
Active Participant
dug9000
Re: Call Executable: RunAs
Do you want a privilege elevation prompt to appear? If not then you will probably have to run the sequence editor or UI itself as administrator.
-Doug
Member
jojp
If possible I want to save user and password in the sequence and run only the executable in a priviledge way.
Member
mkais
Synchronizing with Other User Management Systems – Windows Login
If you enable the Automatically Login Windows System User option on the User Manager tab of the Station Options dialog box, TestStand attempts to log in the current Microsoft Windows user name in the TestStand user list. If the user name is found in the user list, TestStand automatically logs in the user at the appropriate level without prompting for a password. If the user name is not found, TestStand prompts the user to log in. In order to use this option, you must create a user entry in the TestStand User Manager and enter the Windows login name for the user as their TestStand login name.
If I understand your second question well: you qould like to insert a call Executable and add an Executable to your sequence and start it as Admin?
Kais Mekacher
Germany - Munich
Member
jojp
Thanks you I will test your solution.
You understood me right. It would me nice if the need of one executable would not create a need to the security level in general.
But now I also challenge the personen providing the executable to create a new version with no need for Administator right (:smileyhappy:)
Member
mkais
Ok I was speaking with our Teststand Expert and he ave me an Idea:
Look please at this KB:
Run a program with administrative credentials
http://technet.microsoft.com/en-us/library/cc781763%28v=ws.10%29.aspx
I hope it helps:smileywink:
Kais Mekacher
Germany - Munich
Member
jojp
Awesome, thanks. Seems I was searching in the wrong direction.
Member
jojp
Unfortunatly I can´t create a Administrator profil without password on my PC. This result in runas always asking for a password. You can save the password in the shell environment, but after a reboot you have to insert it again.
So I tried to run SequenceEditor with Admin rights an this helped.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
