04-01-2014 06:16 AM
Hi all
I'm having an exceptions on all of NI TestStand 2013 User Interface examples.
The exception is "Unknown Error" of type COMException.
I have trial license.
Does someone can explain how to fix the problem?
Tnx
04-01-2014 06:39 AM - edited 04-01-2014 06:40 AM
First guess: Wrong active TS version.
Please verify with the version selector tool that the correct version of TS for these UIs is the active one.
Norbert
EDIT: Also possible is an incorrect registration of TS on the system. So re-activating the same TS version might solve the issue as well.
04-01-2014 08:26 AM
Hi Norbert,
I use trial license....
Can you guide me what to check???
04-01-2014 09:34 AM
What happens if you run the sequence editor? If you run the NI License manager what does it show for TestStand?
-Doug
04-01-2014 09:37 AM
Hi Doug,
Please find attached print screen of the NI manager
04-01-2014 09:51 AM
So does the NI Sequence Editor start properly? Please answer all questions...
Norbert
