NI TestStand
Breakpoints File
Last week I set a couple of breakpoints in my process model (on a pc with a deployment license), I ran a test and then manually removed them; or at least thats what I thought because they were appearing to the operators during the weekend. I had to go to [Debug>>Breakpoints>>Delete All] to get rid of them, which I guess is the normal procedure to do it. It was strange to me that this happened because I have a deployment license and my whole short teststand life I had the wrong idea that they were being stored in the seq file so, can someone illuminate me and tell me where are they being stored???
Thanx,
Iñaki
(3,124 Views)
They are stored in \Program Files\National Instruments\TestStand 3.5\Cfg\TeststandPersistedOptions.opt.
(3,120 Views)
Thank you drohacek,
Iñaki
(3,097 Views)
Iñaki -
The file that David mentioned is the file that TestStand uses when no workspace is loaded. If a workspace is loaded TestStand creates a file with the same name as the workspace with the .opt extension, and TestStand saves the breakpoint and workspace information in this file instead of the default.
Scott Richardson
(3,074 Views)
