08-03-2014 04:15 AM
I am using Test Stand 3.5 and came arcoss an issue: when the test sequence ends, ocassionally the batch result will not pop up automatically. The result will only pop up when I click a mouse button or hit a key in the keyboard.
Any idea?
Ryan
08-04-2014 01:15 AM
Hi Ryan,
if the dialog box is application-modal, it won't pop up if another application has the focus or at least TS does not have it.
Could this be an issue?
Oli
08-06-2014 12:29 AM
Hi Oli,
Yes it could be. Acutually, my test sequence will call a .bat batch file which in turn call an execute file to perform some action. I now suspect there is something wrong with the execution of the execute file which holds the focus.
Thanks for the input.
Ryan
