07-10-2013 01:42 AM
hi guys,
the array output from a Labview VI (module adapter), how can the teststand consider this Input to be dynamic in size
& do the needed (allocation of mem etc) during runtime based on the input.
I need to report these array values in ATML report and expect them to be visible similar in a tdm report.
thanks for ur suggesions
07-11-2013 09:38 AM
Hi
I have no exact idea what you want. If I understand you right, so you want a dynamic Array in TestStand.
Is no problem. Make a array variable and make a check to empty array. Now you can pass different sizes of
arrays from LabVIEW array output to TestStand array variable.
If you want to have the array in the report,then add an additional result in your Step.
