Array out(dynamic size) from Labview module adapter
hi guys,
the array  output from a Labview VI (module adapter),  how can the teststand  consider this Input to be dynamic in size
& do  the  needed (allocation of mem etc) during runtime based on the input.
I need to report these array values in ATML report and expect them to be visible similar  in a tdm report.
thanks for ur suggesions
(3,361 Views)
Hi
I have no exact idea  what you want. If I understand you right, so you want a dynamic Array in TestStand.
Is no problem. Make a array variable and make a check to empty array. Now you can pass different sizes of
arrays from LabVIEW array output to TestStand array variable.
If you want to have the array in the report,then add an additional result in your Step.
(3,339 Views)
