09-11-2013 02:18 PM
I'm new to TestStand but am a CLD. I've taken a 3-day custom course that covered most of TestStand Core 1 and some of Core 2. I'm using TestStand 2013 and LabVIEW 2013.
I have a VI that needs an input of a cluster containing, in this order:
1D array of strings named Column_Labels
2D array of doubles named Results_Data
1D array of paths named Graphics_File_Paths
1D array of booleans named Pass_Fail
In TestStand I created a custom data type called Maxim_Results from the VI module tab in the sequence. When I reference a local (MINSYS_Reuslts) that is made from this Type I get the following error:
No corresponding subproperty in argument 'Locals.MINSYS_Results' of type 'Maxim_Results' for cluster element 'Maxim_Results.Column_Labels'
If, however, I reference each container element to each cluster element separatley there is no error:
Can anyone help me understand why this is happening?
Solved! Go to Solution.
09-11-2013 03:21 PM
Hey Kelly,
I just set up the situation you described, and it worked properly for me. However, I did notice that in your example where you referenced each element individually, your Column_Labels element is actually called "Column_Lables". If this was also misspelled in the LabVIEW Cluster Passing setting for the custom type, it would cause the behavior you're seeing. Could this possibly be the case?
09-11-2013 03:47 PM
You gave me something to look at. I didn't actually create the sequence and container, it was done by someone else then passed to me. When I took a closer look at the type in the sequence one of the arrays was marked as "Exclude When Passing Cluster" and the checkbox couldn't be cleared. I deleted the variables and type then created the type from the cluster and the created the local using the type. Everything works correctly now.
