02-20-2008 07:24 AM
I dont think the problem is in that sequence. I think its in the MainSequence that calls that step Excel-Set Cell Color - green.
If you can post that MainSequence. Dont need all the subsequence so if you want to remove them and just leave the MainSequence in the Sequence File.
Ray
02-20-2008 08:17 AM
Hi Ray,
I am attaching the program with the subsequences removed.
Let me know if you have any questions.
02-20-2008 09:49 AM
I guessing here, you have some local arrays of size 50 in the MainSequence.
Your error seems to be on row 51 of the excel sheet, therefore you may have exceeded this size.
Try increasing these arrays
In the mean time I will keep looking.
Regards
02-20-2008 12:58 PM
02-20-2008 01:38 PM
Hi Ray,
Those arrays store fault codes. I have never had 50 active, but can bump the arrays up to 100 just to be safe. I think the location of the Run-Time error is a coincidence.
B.W.
02-20-2008 02:38 PM
I think it maybe the flow control step. No need to change your array sizes.
How often does this occur?
How long has the sequence been running when the error occurs?
In the Station Options | Preferences select Debug Options and switch on some or all of the check boxes to see if any other information maybe generated the next time it happens.
Regards
Ray
02-20-2008 04:23 PM
Hi Ray,
We run this program on 2 test benches.
On my bench, this error is sort of random. Sometimes the program completes all of the cycles, other times it dies when it gets close to the end. The end is 1440 cycles. I have seen it stop mostly when it gets above 1000 cycles, sometimes less, sometimes when less than 100 cycles.
On the other bench, it seems to stop near the same place every time (490 - 500 cycles), and has never completed the 1440 cycles. It is shown back in Message 6.
I will select those options and run the test again tonight on my bench. The guy that runs the other bench is in a different facility and he is out of town this week.
B.W.
02-21-2008 07:41 AM
Hi Ray,
I ran the test again last night. It made it to cycle 1320 and stopped with the Run-Time Error. I did not see anything generated by the boxes you told me to check.
You have led me to believe that the error may be caused by something that happens before the Excel - Set Cell Color step. I am going to look at how the Active_Faults_Before, Active_Faults_Now, and New_Active_Faults arrays interact with each other. It looks to me like the No new Active Fault Codes test fails and the program locks up trying to display the new fault codes in the Excel cell. It prints the word FAIL, but I am not seeing the new Active Fault Codes in the Excel cell when the error occurs (see Message 6).
Thanks again for your help.
B.W.
02-21-2008 08:49 AM
02-21-2008 09:44 AM
I've not seen that before.
Ray
