11-05-2013 05:34 AM
Hi All,
I wonder if there is a way to append 1D array to another 1D array in TestStand other than by copying element by element in a loop?
Also if a part of array, say, Array_1 which has 10 element need its elements from 5 to 10 to be appended to another array at the bottom. currently I use loop. But I wonder other than looping each element of the array to another array is there any standard functions or TS APIs available like in LabVIEW?
JKV
11-05-2013 08:56 AM
SetNumElements(Locals.Sum, (GetNumElements(Locals.Array1) + GetNumElements(Locals.Array2))), //Allocate Array For Sum
Locals.Sum = Locals.Array1 + Locals.Array2
It worked for me.
11-05-2013 09:03 AM
Actually you don't even need the first line. It still works.
To get a subset of an array you can copy the array over to a temporary array and then use the RemoveElements() function to remove the parts you don't want. Then add that temporary array to your other array.
Hope this helps,
11-05-2013 09:12 AM
@JKV999 wrote:
Hi All,
JKV
For the second question, in newer versions of TestStand (I think this feature was added in 2012), you can do the following:
Locals.newArray += Locals.Array_1[5..9] // NOTE: assuming array is 0-based so has elements 0-9
-Doug
11-06-2013 12:27 AM
