Hi everyone, I am testing using the TestUUTs method. After a "specific" Main Sequence step fails I want the step to say "FAILED" and I want the Test Executive to "EXIT TEST" so that the "ENTER UUT SERIAL NUMBER" message box does not come up. Basically, I want to shut down the "TestUUTs" loop.
Is there a Runtime.Engine call or another way to do this in TestStand?
Thanks Jiggawax for the quick reply. I have TestStand 2013 so I cannot open the file you attached since it is in TestStand 2014. Can you resave the file as 2013 and re-attach?
